The only problem I have With PVC in a wing rack is lack of versatility,, once you glue it up, you're stuck with that configuration.
I use the old fashioned face out shelf standards and add pipe insulation for cushion, they are easily adjusted if I want to reconfigure things
Now, your issue with having 40 + planes??? I think you need to talk with a PHD about that
