ORIGINAL: sscherin
Man I loved my old .40 Tele with a OS FS-61 on it..
The only mod I would recommend is to add some tail bracing or extend part of the vertical stab down through into the fuse.
The tail to fuse join was the major weak point for me..
Everything else was solid.
Flying my 40 tele in 1987
http://youtu.be/IEcSjY5KkoM
Interesting that you should bring that very detail up, I do plan to do just as you have suggested, this is the only thing I have seen that I thought could use a bit of strengthening. I will use a trick I learned long ago to keep from popping a rudder off, the rudder sets into the slot you build into the stab, then this whole affair is attached to the back end of the fus.
I will add bamboo dowel pins into the rudder that will be attached to a block under the stab/fus. This should add additional strength and stability to the tail. I also thought about adding wire bracing, seen this on another Tele, but have not made up my mind. I also was wondering since I was up-gunning w/a bigger engine, which was here today, but mailman took back to PO f/me to sign, I was @ work of course! Adding wing braces? I understand if you give too much throttle, you induce wing flutter????? Any help would be great appreciated.
