RE: Not wanting bellcrank
There is no reason why you could not have small exit holes in the side of the fuselage though just for the lead outs. Maybe you could fabricate a removable lead out guide at the tip when not flying? It will have to be there though for sure. It could be made out of a transparent material so it will not be as easily seen. You do need to adhere to the vertical CG though.
