RE: DZ170 Throttle Linkage
Hi, thanks for the responses. i am also running a hyde mount and nose ring so in theory i should be ok if it works for you. i will try my tubing setup first, if i still battle with the engine cut out, then i will move to a rigid setup. all the best, roly.
