Old 05-10-2011, 06:51 PM
Fixed Wing
Fixed Wing's Avatar
Default RE: Dean Connectors
Tin the 10G wire and let it cool. Use a dremel cutoff wheel to cut a slot in the center of the end of the tinned wire. Push Dean's tab into the cut slot. Should be a snug fit. Use solder iron to heat and bond. Cover with shrink wrap. Works like a charm.
