RE: Sig LT-40 Float Question
Heat-bonded coverings stick awesomely to sealed surfaces. Just don' t try to remove them. Doped surfaces have been considered effective for years. WBPU also receives covering well. Turn down the heat on your iron so it only activates the adhesive and does not cause the covering to off-gas or you will get blisters.
