Wiring help for separate retract batt for JR S791
Am using a JR S791 retract servo that only runs on 4.8V.
Am using a 6V pack for the RX supply on an AR7000 to supply control surface servos.
Am using a separate 4.8V pack run thru a switch to supply the retract servo so in case of a retract issue RX pack won't draw down or go into brownout.
2 QUESTIONS.
Will running 6V to the RX cause any issues as far as the signal to the servo?
Is my wiring schematic correct for hooking this up?
