RCU Forums - View Single Post - Boiling Tires Off Rims (pic included)
Old 05-29-2011, 09:22 AM
378's Avatar
Default RE: Boiling Tires Off Rims (pic included)
I have two tips if you want to re-use rims after the tires wear out. First, when gluing them, only glue four points on each bead. Secondly, if you've done first, you should be able to just pry the worn tires off, then a file or some careful dremel work will take care of the remains of the old bead, leaving the rim ready for it's new meats.
Or get beadlocks.
