ORIGINAL: SinCityJets
One final thought, please be very careful using these packs as receiver packs. Their discharge ''C'' rating is not very high and you may find yourself drawing more amps than these batteries can supply (especially in the larger birds with a high servo count). If it works for you, great, just BE CAREFUL!!!
Chad
This should be observed for all AA size battery packs the internal resistance has a big effect when trying to draw larger currents, C and Sub C packs should only be used for high current draws. Now if Sanyo could come out with a Sub C size 3000mah+ Eneloop battery we would have the perfect Model aircraft battery.
