ORIGINAL: KitBuilder
I'm curious why you say ''you will never get them both traveling the same and never get the correct differential''? We all (well some) had differential, mechanically, before computer radios. Are yo you saying it's not easy to change it if not correct the first time?
Kinda makes you wonder, don't it??? Perhaps setting up a control rod system is now a lost art?? I do find using my radio to do my set up and trim easier but after it is set I do it again the old fashion way, I twist the clevises then zero my radio trims. I do it all manually before the plane ever leaves my shop but after flight trim I do it again. Guess my age is showing again? Or is it still knowledge??
