RE: *SD-10G Keep Losing Expo*
I don't think this is a problem at all, although possibly a addition to the programing later would be possible, by allowing for a COMmon option on Dual rates and Expo.
Personally I like the fact that I can set D/R on any flight mode and any dual rate selection.
Seems as though whats happening is this for example.
You set up a D/R and or a Expo in Normal flight mode and no other flight modes or dual rate setups.
But by default flight modes are programed and dual rate/Expo switches are assigned.
We go to fly with a switch changing a dual rate or flight mode and bam it feels wrong!.
The user needs to either remove the switch assignments or set the rates and expo for the possible options.
MIke R
