SD10 Flap to Elevator mix problem
I have crow set up on the throttle stick set to activate at 75%. I'm trying to mix down elevator with the crow to counter the nose up pitch when crow is activated. I've got the mix on a straight linear Point #1 is 50%, Point #5 is 0 and Point #9 is -50%. When I move the throttle stick and the crow activates @ 75% I get a momentary UP elevator then it moves down. When I retract crow @ 75% the elevator momentarily moves UP then to neutral. If I change the activation point to 100% the elevator moves to a slightly UP position andstays there, like it thinks that isneutral. I'm at a loss as to what is causing the momentary UP elevator. Does anyone have any ideas? Thanks for any help.
