RE: SD10 Flap to Elevator mix problem
I'll give you the setup for this in a few. Need to get my tx out. In the mean time pay attention to the I O screen it is reflecting exactly what you discribe and holds the answer
Mike r
P.S. i gotta run, but go into FL-EL mix and set point 5 to say 10% and the point q to 40%. You should now see what your looking for. Possibly need negative values for your setup.
I'm also trying to build a spread sheet gor model setup
