ORIGINAL: tadawson
Enable StSw in the GV-1 . . . that is what is required to have the GV-1 drop offline based on stick position (StickSwitch)
Without that (which is the default) it ignores stick position once engaged.
- Tim
You were exactly correct Tim. I brought up the StSw menu and sure enough, it was INH. I punched the data button
once and then it indicated OFF. Advancing the throttle stick past about 25% it shows ON. ON, OFF, ON, OFF :-)
Thanks!
-Kaos
