RE: Why don't the volt watchers work w/2.4ghz
If I recall, Volt Watch is rated for 4 cell 4.8 Volt RX Packs and if you use 5 cell 6 Volt packs you have to cut a jumper wire; so the question is what size volt packs were/are you using? This could be the problem.
