RCU Forums - View Single Post - HL IR system
Thread: HL IR system
Old 06-23-2011 | 11:27 AM
borealis's Avatar
borealis
Default RE: HL IR system
ORIGINAL: martin loo
A: 1 x RX-18 Multifunction Board. < NO NEED - understood
B: 1 x IR Sensor Tower Mount ***NEW ITEM*** - understood
C: 1 x 3pin - 3pin cables.
D: 1 x 8pin Connector Harness.
E: 1 x High Voltage Flash Unit. < NO NEED - ?? due to airsoft, if no shooting required then fixable? You might need this if you disconnect the airsoft power feed and plug the flash into the barrel
F: 1 x IR Sensor Tower.
G: 3 x 2pin Red/Black cables. < NO NEED - kinda understood
H: 1 x 8pin - 5pin cable.
I: 1 x 8pin - 8pin cable. < NO NEED - kinda understood
J: 1 x Standard L.E.D w/wire.
K: 1 x TK-YL101-1 Receiver Board with 3pin-3pin < NO NEED - what`s actually use for? Its the receiver board you should already have
Lastly, you quote buying complete IR turret means buy a complete tank model with built in IR systems? If your tank already has smoke and sound, then it probably has the RX18 board in. In this case the same board is used for both airsoft and IR versions. Therefore you just need the turret with barrel recoil, IR led and IR receiver to swap with your airsoft one
Thanks again in advance!
