RE: Help! Warped spar
Windex is fine. Make sure you slightly overcorrect the bend and when the pins are pulled it should be straight. It may take mre than one attempt.
You can buy ammonia in any store that sells household cleaning supplies (like Windex).
The idea of cutting a new spar is a third way to go (unless your LHS is a long distance away)
Walt
