RE: kyosho Kelly F-1
Thanks for the prop tip. I need to keep the pitch around 8.5 or so for a target speed of 155 + -. The Toni is a little chunky around the middle, and I do not think it will go much faster than that. How well does the boiling trick work? That would be great if it did, even if they were only good for a few flights.
For your plane, I believeeither ZZ proips orEliminator makes a 9x10 in carbon for around 16 bucks. That should scoot on a slippery plane.
