RE: K 80 programing help
If your motor came with the Hausel pump it should have been calibrated at the factory. If you are converting from Flight works to the Hausel pump parameters should be the same but I will confirm on Monday. Please give me a call on Monday so I can get the parameter from one of our airplanes.
