go on run the storm! you know you want to [&:] after tuning i have realised i need taller gearing on the car because its front wheels just dont touch the ground. and its top speed is immense but it does run out of revs before it runs out of power so does need a smaller CB. but the power i get from this used truggy engine is still too much for this little car, chucks it around dohnuts on command and will perform a rolling burnout when the tires are cold. all i need is some front brakes and i can make it look like a proper dragster. and the only other change is it needs much thicker shock oil... i remember putting in some un-labeled shock oil about a year ago and it was far too thin. but because i mothballed it i never knew.
And the new Duke Nukem is truly dreadful but to be fair the original was just as bad... its just more of a joke than a proper game.
portal 2 is where its at
