Ignition Switch/Charge Port & 2.4GHz RX
I would like to place both the Ignition and Receiver Battery Switch/Charge Port in the same Fuselage Switch Compartment that will also hold the Air Fill Valve, Air pressure gauge, etc; I am using 2.4GHz Futaba Fasst, and the RX placement will be in close proximity to these switches; I will also be using a Opti-Kill Transmitter operated Ignition Kill set up; any problems with interference with the RX, I know on 72MHz you had to place the Ignition Switch as far a way from the RX as possible; is this still the case with 2.4GHz?
Thanks.
