RE: Static Servo Setup using DX7
I have most stuff in a "default 5 channel setup" model on my DX7 with all of the basics used. Most of my planes use 5 with a couple that use 6 channels (split elevator requiring 2 servos) All the basic mix stuff is set up in the default including a throttle kill mix.
My question is: do ya set up the mechanical trim (servo arm hole & horn hole) using 100% servo deflection for the low rate settings and use the radio features to adjust for high rate settings? Or, do ya set up the mechanical trim using 100% servo deflection for the high rate settings and use the radio features to adjust for low rate settings?
