RE: Lanier Laser 200 33% kit completion
Since that picture was taken, I have cut out the center section between the two holes. Beyond that, the way the cowling on a Laser 200 meets the fuselage, I am going to put vent intakes on either side. Between the three openings, I should be able to get sufficient airflow through the tunnel. The outlet will be in the bottom of the fuse behind the radio bay.
