RE: 12X Programing Help Needed for Fixed Wing
To tie the flap positions to the flight mode is very similar to associating various rates to the flight mode switch. After you have established the flight modes in the DeviceSEL menu (#17) go to the FLAP SYS menu (#66). On the right of the screen is a column labeled Flight Mode. For each of the modes you can choose either to have the flap switch select the flap settingor the flight mode switch position to be one of the three flap settings in the menu.
Aquick way to tie the flap positions to the flight mode is to designate the flap switch as your flight mode switch. If you do, you will lose some flexibility in programming.
In the program mixes set the Pos.1 rates for the mix. On the right hand half of the normal mixes are a bunch of select switches which if they are turned on, the mix’s Pos.1 rates come into play. FM-0, FM-1, FM-2, etc. are the select switches for the flight modes. Pos.0 rates are used when none of the select switches is turned on. The curve mixes work the same except you have to select SW SEL before getting the select switches.
Allan
