Old 07-06-2011, 01:01 AM
ozzieflyer
Default Switch settings for 12FG
Have just moved to a Futaba 12FG, after 13+ years on a JR 10x.
So am working out the best switch setups.
The first thing, as I am mode 2, I got the spring loaded switch moved form the right hand side to the left hand side, this seemed to make more sense to me for Mode 2.
When I use a trainer Tx, I set the Trainer function to this spring switch.
But what about throttle cut and timer start?
The JR had an analogue trim for throttle so I never needed or knew about throttle cut. What's the best place/switch to put this on?
The timer on the JR was started from the touch screen, (one thing I miss on my 12FG)
And the timer start? I currently have the timer start on one of the spare T6 trims, seems to work ok, but not sure where to put the throttle cut, as I want to make it consisten for all my fture models.
Comments and experience appreaciated.
