RE: JR R921 Receiver battery question
I have a 921 in a 50cc Extra and have noticed that with one battery plugged into the batt/bind port, and a second battery plugged into the data port, it draws from the battery plugged into the batt/bind port while the battery plugged into the data port remains at it's charged voltage.
Does the 921 draw from one battery until it's voltage reaches some minimum value and then draws from the second battery? I expected it to use both batteries at some kind of similar rate but that isn't happening.
Paul
