Soarrich You were right. When I put the newly cleaned carb back on, the gasket between the Insalator and the block fell off one of the bolts. This was on the bottom of the carb. Did not see it and tightened it up. Put the gasket back in its proper place and its running better the ever. THANKS
Stuka Jon
