Thread: Buddy Box
Old 07-13-2011, 05:00 AM
BuschBarber
Default RE: Buddy Box
ORIGINAL: tburlington
I am using an older JR PCM10 radio. Can I use a buddy box with this radio?
If it has a Trainer port on the Tx than it most likely can be used with a Buddy Box. The JR/Spektrum Trainer Cord usually has 1/8" Audio connectors on either end. Unlike Futaba, the Buddy Box must have it's own battery. When you plug in the Trainer Cord, the display will power up, but the Master will not Transmit until you turn on the Power Switch. Do not turn on the Power Switch for the Slave Tx.
