RE: It's here and Looks GOOD new Hangar 9 Taylorcraft
I did some checking and the 182 would completely fit within the cowl on center line if it were some how equipped with a prop hub extension so as to be located closer to the fire wall, though I don't recall exactly how long. A prop hub extension would take a little lathe work with perhaps using a four bolt prop scheme but it would be doable.
