RE: 8eight-T 2.0 Race Roller
HI fellas,
So i did all that was suggested and all checked out. So i ordered a list of parts that was needed as follows.
A Main Hobbies
Order Number:
Date Ordered: Wednesday, July 27, 2011
Products
1 x Savox SC-1256TG Standard Digital "High Torque" Titanium Gear Servo (SAV-SC-1256TG) = $79.99
1 x Savox SC-0252MG Standard Digital Metal Gear Servo (SAV-SC-0252MG) = $37.99
1 x JR Standard Switch (JSP98010) = $6.99
1 x Losi Aluminum Servo Arm (FUT) (LOSA99032) = $9.25
1 x Racers Edge Aluminum Double Arm Futaba Servo Horn (Hard Anodized) (RCE10371HA) = $6.39
A Main Hobbies
Order Number:
Date Ordered: Tuesday, July 26, 2011
Products
1 x ProTek R/C Li-Ion and Li-Poly 6.2V/5A Nitro Servo Regulator (PTK-LVR-5A) = $29.99
1 x Losi Quick Change Engine Mount Set (8IGHT/8IGHT-T 2.0) (LOSA9155) = $45.99
1 x Losi 8-32x1/2” Flat Head Screws (10) (LOSA6262) = $2.79
1 x Losi #8 Countersink Washers (8) (LOSA6351) = $4.59
1 x Losi 15mm Shock Boot Set (4) (LOSA5426) = $6.39
1 x Losi Body Mount Set: 8T (LOSA4436) = $3.69
1 x Losi 6x10x3mm Rubber Sealed Ball Bearing (LOSA6946) = $12.75
1 x Losi 4-40x1/2” Cap-Head Screws (10) (LOSA6204) = $1.89
1 x Losi #4 & 1/8” Hardened Washers (LOSA6350) = $2.79
1 x Losi Radio Tray and Mounts (2.0) (LOSA4421) = $16.99
1 x Losi Clutch Bearing Set (LOSA6949) = $6.39
1 x Losi 4 Shoe Clutch Pins & Hardware (8IGHT 2.0) (LOSA9106) = $6.39
1 x Losi Air Filter Foams Pre-oiled (4) (LOSA9151) = $8.25
I am going to run a Jammin JPX.28 engine coupled with JP-4 pipe and header..
Diff oils i went with 5k front/ 10k center/ 3k rear to start with. shock oil is 30 front and 35 rear.. This is all startings points and will fine tune from here..
