RCU Forums - View Single Post - will this make a difference?
Old 08-01-2011, 08:51 AM
opjose
opjose's Avatar
Default RE: will this make a difference?
It is normally OK to replace an existing prop with one from a different manufacturer, provided that the prop is of the same size, pitch and type.
So if you purchase a slow flyer or GWS prop of the same diameter and pitch of the one you are missing, you should keep thing within the specs of your electronics.
However if you get something larger or of higher pitch, that will cause the new prop to draw more power from the ESC and motor, resulting in frying your components.
