Sorry a slip of the finger... SRS cockpit
http://www.powerbox-systems.com/e/po...-srs/start.php
This may be of interest if you had not seen it before.
11 channels, plus 1 sequencer.
Complete receiver redundancy, double the security
Complete battery redundancy: two batteries, two electronic switches, redundant output voltage with dual regulation
The unit saves receiver data, such as "lost frames" and "failsafes", for all connected receivers - whether Spektrum, Futaba, Multiplex, Jeti. Data can be read out after the flight on the OLED screen.
Integral freely programmable door sequencer
You need to read the manual carefully to understand exactly what this can do. As I understand it this uses a 'normal' servo arrangement downstream of the Cockpit unit but can use the 2 S bus receivers. It looks a very powerful system.
John
