RE: Meister Platinum 109 or Bust Ya'll!!
Once the spar had time to dry, I tack glued all the ribs to the spar then secured it to the table. The build tabs make it really easy to align each rib and assure correct wash out once the sheeting is complete.
After I was happy with all the alignment, I glued the leading edge and trailing edge hardwood forms. The nice part is, once everything sort of "snaps" into place, you know its straight. I love the simplicity of this wing so far!
Some light sanding is required to make sure the sheeting will lay flush once it is glued on.
