Removing Epoxied in hinges
Metal hinges? Yikes!
A lot of heat might work, but be careful of the covering. (Unless you're stripping that too.) Apply heat to one hinge and pull firmly and constantly once heat's been on it for a while.
Other than that, I'd use a Dremel cut-off wheel. You'll have to put new hinges in a different spot anyway.
Dennis-
