RE: Is this a software problem on my DSX11
Hi Nigel,
Glad to hear you like the radio.
On the SD issue - the SD card needs to be formatted (check on a PC), not write-protected (little slider on the side), and the root directory can't be full (lots of files). We tested using cards from 64M (yes, Meg!) up to 32G. While unlikely, it's possible that there's an SD card out there that just isn't compatible. Try another card (empty preferred) to start and please let me know what happens. I usually get PMs quicker than coming here, if you need it quickly.
On the timer issue, when you're on the main screen you can reset your timer by pressing the CLEAR button. The DX8 only has 1 programmable timer. What's the second one you're talking about? The internal time just counts total usage of a model, it's always running, and it doesn't make any alarms.
Andy
