Old 08-06-2011, 09:51 AM
Rodney
Default RE: eratic servo control
If you still have problems with the on board telemetry off, you most probably have some bad connection between the receiver and servos or between the battery and receiver. Check all your connectors for corrosion (a common problem with boats especially if used on other than very pure * no salt* water).
