RE: need a 10 c expert
Frank,
There is a pretty easy way to do it
go into the Basic Menu-
>AUX-CH
>CH6 (or what ever channel you flaps are on)
>assign SwC (switch "C",, that is the only 3 position switch)
Then go to the End Point menu
Center switch position will be your "mid flap" position,, you can fine tune that with the sub trim, (just keep in mind that will move the other end points too)
Adjust your up and down Zero and Full flaps with the end point menu,
You're done
good luck
