Old 08-06-2011, 05:42 PM
A.T.
Default RE: Y on a battery
ORIGINAL: telejojo Can you use a y on a channel with a bat. and another function.I have run out of channels and need a slot for battery and ign. cut off switch and was thinking about using a y all I need for the ign. is a signal wire and a hot wire for the bat.
Yes, examples:
Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid Brownout & Add Redundancy, even one for each servo.
<dt>Separate Battery for Retract Servo - DIY harness. 01 </dt><dt>Separate Battery for Retract Servo - DIY harness. 02
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(quick search = Ctrl+F)
</dt>
