RE: Crashed enya 90 4C
It depends on how much case hardening was done or not. Give it a try and see if you can straighten it or not. The worse that can happen is the bent end snaps off on you. If it doesn't and you get it straight, then you don't have to find a new crankshaft or make one. You can't use it bent anyway.
