ORIGINAL: billberry189
Good Morning Duane!!! I have been working on my fin and rudder this morning and I was wondering how much throw is needed on the rudder. Right now I'm at about 4 1/2'' side to side at the widest point. Is that enough or does it need to be more?
I'm getting this feeling you're a better builder than I am. I never measured.[8D]
There are two methods for the control surfaces I've used...one was employed by Vic Husak on his King Altair, the other seen on Ed Kazmirski's planes. Vic used a 45-degree bevel of the control surface so it comes to a point where the hinge is placed so you (at least theoretically), get a full 45 degrees in each direction. Ed in all his planes simply rounds the control surface uniformly so there is no real limit. When I build the King, I make the "bevel"...and when I build a Kazmirski plane, I round the surface...including the Simla. Builder's choice. I always try to get as much rudder throw as possible when building, then adjust throw to get the flying characteristics I want. I like a lot of throw for Stall Turns.
Duane
