RE: Help me set up my DX7 with retracts please
my rx is only a 6 channel rx, so I'm using one channel for the ailerons which are on a Y splitter, and I'm using two channels for each retract servo. The problem is somewhere in the mixing. I have set Aux2 to INH and in mix1 I have made Gear the master and AUX the slave and set the rates at 100%. But when I flip the switch, only one servo is moving. If I swap the ports for the two retract servos, the other servo starts moving and the one that was moving stops. I have also tried another rx and same deal.
