wheres the clutch going to go if you put a alternator in there? (Please see the above picture)<o></o>
do you put the clutch infront of that ?( Consistent with the picture installation direction)<o></o>
and what if i have i powered kill switch installed ?( Do not understand)<o></o>
i have to turn the battery on so i get the green light and then i can start the 5b (After engine start, open the switch on the PCB, there is a power supply for use by the servo)<o></o>
plus guys he is saying there is NO BATTERY so its only working when the engine running to send power to the reciever , dont know if you could add a battery to this so the alternator maintains a charge to it , and hopefully it doesnt over charge it aswell .( Car batteries should be removed completely without batteries, the car can travel)<o></o>
