RE: Elevators will not sync W/11X
John,
How did you mate AUX3 to your elevator? Did you use the DUAL mate in the Wing Type menu or did you use a program mix? Rob2160 offered some good suggestions if the problem is mechanical. However, you should first check if it is in the way you mated the elevator channels. Take a look at the Monitor menu and see if both channels go the same distance with the stick hard over. If you used the Dual to mate, the channels by default will go in opposite directions. I can think of several ways that using a program mix will cause the channels to move unequally. Also, check the Limit Adj. as well as the Travel Adj.
Allan
