RE: shengqi baja tx
Wow if its not 1 thing its anothe. Fixed my diff meshing by puting a piece of paper folded over to create 2 sheets between the gears, loosening the engine then shfting it back then tightening. Perfect mesh, but on testing I hit a rock and now the steering servo makes a grinding noise when I turn. I can't afford a new 1/5 scale servo riht now so am searching for servo gears that ******** currently do not have in stock. It still turns when being driven but am guessing it will get worse and end up fully broke. Is there a cheaper way of fixing this?
Also can a standard size servo handle 5th scales?
