ORIGINAL: Altered1
Hi all,
I have an ENYA 60X, and a problem I originally thought was air in the lines from foaming fuel.
I'm using this in an airboat, so an engine stoppage is not a drastic problem, but it's annoying...
I now think that I may have too much prop, as I have replaced all hoses, checked the tank, replaced the clunk, padded the tank more, balanced the props.... everything I can think of.
I started off running a 12x6 APC, and the engine would start fine, and warm up without any problems..... but when I spin up to full power to move off and start some fun, she stops after 15 seconds or so... Once I changed to a 11x6 APC, I managed to have it run for several minutes at full power before it stopped. Running leaner or richer does not seem to have any marked effect. The stop is abrupt - no bogging down or leaning out that I can hear. She just dies.
The engine doesn't sound to be over propped, but I got the improvement in run time with 1' less diameter prop. Once I resize a 10x6 I was running on another engine (ASP52) I'll give that a go too.
so - has anyone experienced similar problems - am I on the right track ?
All information I find tells me this engine should be able to spin a 12x6 easily, and all day.
Thanks for any thoughts you may have
Altered1
