RE: Too much prop stopping ENYA 60X ?
His engine should have the G8 carb which is more forgiving than larger ones used on newer versions. Try changing the plug and isolating the fuel system. Keep the rpm up with an 11-7 or 12-5, a little nitro will help broaden the carb mixture and add power.
