RE: Too much prop stopping ENYA 60X ?
Are you using muffler priessure with this small carb? Check the air bleed hole to see if it is clogged. Then check after running to see if there is fuel comming out of the air bleed hole. I believe that on SOME Enya carbs the fuel is mixed with the air from the air bleed line. If muffler pressure is used, or too much muffler pressure the fuel that is normally mixed with the bleed air overpowers the air bleed and will sometimes leak out of the air bleed hole. Or just try it without muffler pressure and see what happens.
