Not in stock form....
Well actually it
was stock when it ran that fast, except for the prop. I was pitted next to Brian when he ran it through the traps at 65 mph. But you'd never run it that way for more than 60 seconds or you'd burn something up - that was a SAW-only setup. In reality the UL-1 can run near 50 safely with everything stock but the prop and connectors. I ran the prototype Motley Crew into the high-40s with just a prop and connector change.
