Spektrum DX3s won't go to main screen
Got a DX3s, when I turn it on it shows CAL VR in the top right corner, and STC on the left side a couple of lines down. No buttons work except the Timer button, which results in same but after the STC it says 518 OK, then on the next line STL. Pushing it again results in the same plus it says at the bottom ERROR:, then on the last line RESET3.2. Any ideas? IT is not under warranty, so sending it in is out of the question....
