RCU Forums - View Single Post - MCX2
Thread: MCX2
Old 08-24-2011 | 08:10 PM
davidgeorge212's Avatar
davidgeorge212
Default RE: MCX2
It could be that when you reassembled the frame of the helicopter, one of the big gears connected to the main blades is not lined up correctly with the pinion gear on the motor. Its been a while since Ive worked on an mcx but check to make sure your gears are properly aligned and spinning the blades.
